tcleland
Mar 27, 2014Aspirant
Crashing during factory reset
Hi folks - This is a new problem based on the ReadyNAS Pro Business 6-disk discussed in viewtopic.php?f=65&t=75720 I finally decided it was time to factory reset the whole system. So I did. B...
Mar 27, 2014Guru - Experienced User
Since all the other devices are happy, it seems unlikely to be the UPS, but it is easy to rule out.
By "system failure" I meant PSU, RAM, a system board component, SATA backplane ... Of course diagnostics aren't 100%, so it could be RAM. But passing the diags does make it seem less likely.
