tcleland
Mar 27, 2014Aspirant
Crashing during factory reset
Hi folks - This is a new problem based on the ReadyNAS Pro Business 6-disk discussed in viewtopic.php?f=65&t=75720 I finally decided it was time to factory reset the whole system. So I did. B...
Mar 27, 2014Guru - Experienced User
Nothing else would be serviceable with my hardware skills...
I can't think of any easy way to isolate it to the PSU, other than replacing it and see. You've already reduced the number of drives, so it doesn't seem likely to be overall power capacity. So it would need to be something more subtle.
