tcleland
Mar 27, 2014Aspirant
Crashing during factory reset
Hi folks - This is a new problem based on the ReadyNAS Pro Business 6-disk discussed in viewtopic.php?f=65&t=75720 I finally decided it was time to factory reset the whole system. So I did. B...
tony359
Mar 27, 2014Apprentice
In the test above drive number 6 is always there and the NAS failed to setup with just that drive. As Stephen said, the Pro6 will work with just one drive. Try another single drive, if that fails as well, then you have a HW problem. The next step could be reseating the connectors and the RAM - even though your memory tests seems ok.
