sdouek's avatar
sdouek
Guide
Jul 07, 2015
CrashPlan Cheat Sheet and Tweaks
lBelow are Command Codes, Tweaks and info on CrashPlan.
If you need me to add any more or if something changes feel free to let me know and I will adjust it.
#As of CrashPlan 4.2, CrashPlan will install their Java to run with their software on you NAS. There is no need to install a new Java on your whole NAS. (In other words EJREInstaller-0.20-readynas-x86.bin by MinimServer is not needed for this install anymore).
#In /usr/local/crashplan/install.vars the JAVACOMMON=/usr/local/crashplan/jre/bin/java.
#CrashPlan tests their software with that specific Java. (Unless you want to do their Quality Assurance for them on a new Java :) )
#If the EJRE addon is already installed on your system DO NOT UNINSTALL IT, it is still needed globally and as per MinimServer.
Uninstalling the Java runtime
To remove the EJRE installation from your ReadyNAS, remove the EJRE Installer add-on. This removes the installed EJRE files, but doesn't remove the original EJRE .tar.gz file from the backup share.
#Seeing What Port NAS is Listening to.
netstat -na | grep LISTEN | grep 42
#Return code should look something like this:
tcp6 0 0 :::4242 :::* LISTEN
tcp6 0 0 ::ffff:YOUR.NAS.IP.ADDRESS:4243 :::* LISTEN
#Starting,Stopping CrashPlan.
#/usr/local/crashplan/bin/
./CrashPlanEngine stop
./CrashPlanEngine status
./CrashPlanEngine start
./CrashPlanEngine restart
OR
/etc/init.d/crashplan [same options as above]
#Unpacking CrashPlan to install.
#/root/
tar -xvf CrashPlan_4.3.0_Linux.tgz
#(4.3.0 change to package number you are installing)
#Installing and Uninstalling CrashPlan (This will not uninstall your .ui_info or .identity file).
#/root/CrashPlan-install/
./CrashPlan-install/install.sh
./CrashPlan-install/uninstall.sh -i /usr/local/crashplan/
#/usr/local/crashplan/conf/my.service.xml
<serviceHost>YOUR.NAS.IP.ADDRESS</serviceHost>
OR
#To have CrashPlan listen on all network interfaces and thus accepting GUI connections from any computer on your home network.
<serviceHost>0.0.0.0</serviceHost>
#"If Watch file system in real time" is not working CrashPlan suggested changes so that it works on a NAS.
#/etc/sysctl.conf
fs.inotify.max_user_watches=1048576
#Increasing Memory Value to CrashPlan Engine.
#Go to CrashPlan on PC and Double Click Home Icon in Upper Right Hand Corner
#Value should be in memory increments of 64, increasing value too high will stop CrashPlan from running. The upper limit on my NAS PRO Business is 3072 and I have 8 GB of Ram installed.
java mx "value"
OR
#Stop CrashPlan
#Edit /usr/local/crashplan/bin/run.conf in SRV_JAVA_OPTS change "-Xmx3072m" to desired value.
#Start CrashPlan
#Configuring CrashPlan Backup set to Exclude all Directories Named "Recycle Bin".
#Located in Settings-Backup-File exclusions:-Configure (Make sure "Regular Expressions" is checked).
./*Recycle Bin.*
#CrashPlan updated to 4.3.0 and now my Windows 7 GUI will not connect.
1) Make sure Windows 7 GUI is 4.3 and make sure it is not running when you are doing the steps below:
2) Copy your .ui_info from your NAS to your desktop:
a) .ui_info on NAS is probably located /var/lib/crashplan (unless you changed it from the default when installing i.e.
What directory do you wish to store backups in? [/usr/local/var/crashplan])
b) .ui_info on your desktop is located C:\ProgramData\CrashPlan. (Rename your old .ui_info to .ui_info.orig)
3) Configure your ui.properies file on you PC appropriately. i.e. service port should be 4200 if you are using ssh to tunnel or service host should be changed to your NAS ip address if you made the proper changes in the my.service.xml file on you NAS.
4) Start up CrashPlan 4.3 on your desktop.
#Another way to check if the CrashPlan service is running in your PC.
ps auxww |grep -i CrashPlanService
#Return code should be something like this:
root 19952 80.3 7.4 3623440 611904 ? SNl 08:17 400:32 /usr/local/crashplan/jre/bin/java -Dfile.encoding=UTF-8 -Dapp=CrashPlanService -DappBaseName=CrashPlan -Xms20m -Xmx3072m -Dsun.net.inetaddr.ttl=300 -Dnetworkaddress.cache.ttl=300 -Dsun.net.inetaddr.negative.ttl=0 -Dnetworkaddress.cache.negative.ttl=0 -Dc42.native.md5.enabled=false -classpath /usr/local/crashplan/lib/com.backup42.desktop.jar:/usr/local/crashplan/lang com.backup42.service.CPService
root 23519 0.0 0.0 4104 504 pts/0 S+ 16:35 0:00 grep -i CrashPlanService
#Installing the CrashPlan app instructions from CrashPlan's Website.
CrashPlan Headless Client Install
ReadyNas Forum - Crashplan for Dummies, aka Step by Step (this is the latest guide so far out of the 18 or so pages in the post).
Crashplan for Dummies, aka Step by Step :)
  • TYPO Error:
    b) .uni_info on your desktop is located C:\ProgramData\CrashPlan. (Rename your old .uni_info to .uni_info.orig)
    .uni_info should read .ui_info
    Thank you StepheB for finding it and pointing it out !
    • StephenB's avatar
      I edited the original.
  • Great cheat sheet. Thanks.
    Perhaps someone more experienced than I can help me troubleshoot this though... Crashplan v3.6.4 was working fine on my ReadyNAS Ultra4+ until recently... I'm not sure if something changed such that we require the latest versions of the clients to work with the CrashPlan service. So, updating to 4.3.0 seemed to work fine after uninstalling 3.6.4, but upon trying to launch 4.3.0 on my ReadyNAS the following is in the engine_error.log:
    /usr/local/crashplan/jre/bin/java: error while loading shared libraries: libdl.so.2: cannot open shared object file: No such file or directory
    Any guidance on what to do about that?
    I verified that "jre-7u45-linux-x64.tgz" properly downloaded and unpacked in the java path set on "JAVACOMMON=/usr/local/crashplan/jre/bin/java"
    I am at a loss right now. Thanks.
    • chriscena's avatar
      chriscena
      I managed to get Crashplan 4.4.1 up and running on my NAS (ReadyNAS Ultra 4). All I had to do was to swap out the x64 JRE package with the 586 version instead, after completing the usual install. The install.defaults file contains the URL for the correct file, so just download that one:
      (I'm doing all of this in ~/crashplan-install/)
      wget http://download.code42.com/installs/proserver/jre/jre-7-linux-i586.tgz
      then unpack and swap the x64 version with the 586 version:
      tar -zxf jre-7-linux-i586.tgz
      mv /usr/local/crashplan/jre/ /usr/local/crashplan/jre-x64
      mv ~/crashplan-install/jre /usr/local/crashplan/jre
      then start the Crashplan service. Voila!
      Obviously, the installer picks the wrong architecture for the NAS. Hope this helps.
      • StephenB's avatar
        That wasn't really my problem.  The upgrade failed right away because the java version was 1.6.  Crashplan did not attempt to update java.
        Wed Sep 23 20:39:17 EDT 2015 : JAVACOMMON is set: /usr/bin/java
        Wed Sep 23 20:39:17 EDT 2015 : Current Java Version: 1.6
        Wed Sep 23 20:39:17 EDT 2015 : This client requires one of these JREs: 1.7 1.8. Exiting upgrade
        Installing jre 1.8 (and changing JAVACOMMON to point to it) solved the problem.
    • kahunamike's avatar
      kahunamike
      Did you ever solve the jre issue? I'm getting the same error message after upgrading to 4.3.0
      • scootle's avatar
        scootle
        Nope, haven't yet solved this issue.  My post was made right before the ReadyNAS.com forums were migrated, so everything was locked during the transition, so I presume nobody was able to read or reply to my inquiry.
        For the time being, I am without a means to run CrashPlan.
        Any suggestions are welcome.  Thanks.
  • This forum and it's users has helped me so much I am Glad to give back to the Community.
  • Thanks for the cheat sheet, good summary and helped me solve why 4.3.0 wasn't connecting from Windows
    Cheers
ProSupport for Business
