itsjasper
May 05, 2017Luminary
Create x86 USB Recovery key using a Mac
So I have inherited a couple of x86 ReadyNAS Pro units that don't successfully boot... 1) a Pro 4 that I can Factory Default, but this still doesn't boot aftar RAIDAR config. An OS reinst...
mdgm-ntgr
Jun 04, 2017NETGEAR Employee Retired
You could try Rufus in a Windows VM. USB Boot Recovery expects the USB key to have a MBR partition table with a single partition. A lot of USB keys have no partition table these days.
I have a USB key that can boot into a tech support mode like state that doesn't care how the USB key was partitioned so long as you can boot off it.
I could prepare a dd image that you could try.
Sandshark
Jun 04, 2017Sensei
I had no joy with any of my newer USB flash drives. I pulled out an old Lexar 2GB drive, and it worked flawlessly. So my advice is: older is better.
