rlyon
Feb 05, 2011Aspirant
creating a website connected to an Airport Extreme
Hello, I followed the personal webserver instructions a http://www.readynas.com/?p=213 and I get to step 3 (http://<readynas_ip> ) and that works, I can see my website. However, the step 4 says to fo...
sphardy1
Feb 08, 2011Apprentice
Provided the port forwarding settings are correct, that's all you should need
Post a screenshot of the settings if you would like them checked out. If they are correct, then I'd be inclined to suspect the modem as the cause of the issue
