yeti4
Sep 17, 2016Aspirant
Credentials for backup from PC and laptop to ReadyNas 102
I have two computers - laptop and PC. Both have Windows 10. I need to make backup from laptop to ReadyNas and from PC to ReadyNas. It works properly, but there is one problem with PC which I can't so...
Sep 17, 2016Guru - Experienced User
you chould be able to see the credential you are using in the laptop by running the windows credential manager. You won't see the password of course, but you will see the username.
yeti4
Because on laptop it works and on my PC doesn't, so I tried in Credential manager to change step by step all logins, but my backup worked all the time. When I changed login in my backup job, it stopped working. So I do not know which credentials are really used by backup to fix it in my PC.
- StephenBSep 18, 2016Guru - Experienced User
Is this a backup job on NAS? Or a backup program running on the PC? If the latter, what program is it?
- yeti4Sep 18, 2016Aspirant
It is backup job on NAS.
