yeti4
Sep 17, 2016Aspirant
Credentials for backup from PC and laptop to ReadyNas 102
I have two computers - laptop and PC. Both have Windows 10. I need to make backup from laptop to ReadyNas and from PC to ReadyNas. It works properly, but there is one problem with PC which I can't so...
yeti4
Because on laptop it works and on my PC doesn't, so I tried in Credential manager to change step by step all logins, but my backup worked all the time. When I changed login in my backup job, it stopped working. So I do not know which credentials are really used by backup to fix it in my PC.
Sep 18, 2016Guru - Experienced User
Is this a backup job on NAS? Or a backup program running on the PC? If the latter, what program is it?
- yeti4Sep 18, 2016Aspirant
It is backup job on NAS.
- StephenBSep 18, 2016Guru - Experienced User
Ok, I was thinking the other way around.
I think the next step is to try and access the PC share from the laptop, and sort out the permissions that way.
Are you using local accounts with PIN disabled on the PC?
- yeti4Sep 19, 2016Aspirant
Connection from laptop to PC doesn't work. Internal network from PC to NAS with credentials works OK. ReadyCloud from PC to NAS doesn't work with credentials ON. When credentials are OFF it works OK. I have noticed, that only when I change login in USER ACCOUNT it has influence on backup job. When I do the same from credential manager it has no influence on backup job. At least I know what for credential I am writing in backup job. I do not use local accounts with PIN.
