Patou034
Mar 22, 2018Aspirant
Curl does not work any more since upgrade to 6.9.3 on RN316
Hello, I'm using following command to shutdown my RN316, but it is no more working since update to 6.9.3 : curl -u admin:$1 -k "https://$2/dbbroker" -H "Content-Type: application/x-www-form-u...
Sandshark
Mar 22, 2018Sensei
In OS6.9.3, access to /dbbroker is now forbidden (403 error). I have not investigated why, but it appears intentional.
Patou034
Mar 23, 2018Aspirant
Thank you for the reply,
Is there Any any solution to remote shutdown ?
- mdgm-ntgrMar 23, 2018NETGEAR Employee Retired
I think this is related to the CSRF security fix. I'll try to find out if there's a way that can do it on 6.9.3 and if not if something could be changed for a future firmware release.
- Patou034Mar 23, 2018Aspirant
Thanks,
- Shadowl0rdMar 25, 2018Aspirant
I Hvae the same problem
It´s possible to downgrate the firmware?
where can I download firware 6.9.0?
