Patou034
Mar 22, 2018Aspirant
Curl does not work any more since upgrade to 6.9.3 on RN316
Hello, I'm using following command to shutdown my RN316, but it is no more working since update to 6.9.3 : curl -u admin:$1 -k "https://$2/dbbroker" -H "Content-Type: application/x-www-form-u...
DIYJeff
Mar 30, 2018Aspirant
Just what I needed. I saw that the it needed the csrfpld token, but did not know how to get it. Thanks my code is now working again.
Aemstel
Mar 31, 2018Tutor
Like Shadowl0rd, I also don't know how to write this code and copy/pasted the code I've been using for years, which now doesn't work anymore. Could anyone with a new working script please share their script here? Preferably for a .bat file, like in the first post. Much appreciated.
- SandsharkMar 31, 2018Sensei
This sounds like a place where Netgear should consider writing a program, so that the password is not stored in the clear. Ideally, something that can be called from a backup job. Even better would be the ability to send a WoL packet as well.
Let's call the program ReadyCTL. Script does:
ReadyCTL wakeup NAS1
<insert backup software command here>
ReadyCTL shutdown NAS1
Before all this, the user configures the program through the GUI with the NAS1 IP address (and others if he has them), admin name, and password and the program stores the name and password encrypted.
Building this into the NAS backup system would also be great.
- StephenBApr 02, 2018Guru - Experienced User
Maybe post this on the idea exchange. FWIW, I'd like to see a general WoL app for OS6 NAS.
