jimbof
Mar 24, 2013Aspirant
Dashboard/Frontview not working
Hello, I've been running a Duo v2 for the past 6 months with all running smoothly but today I can't access the main dashboard :( I put in the correct IP address, get the login screen and then the pag...
chirpa
Mar 26, 2013Luminary
Yes, if you are on SSH, its /var/log/frontview/initrd.log. It is also in the System Log download if performed from the GUI.
