jimbof
Mar 24, 2013Aspirant
Dashboard/Frontview not working
Hello, I've been running a Duo v2 for the past 6 months with all running smoothly but today I can't access the main dashboard :( I put in the correct IP address, get the login screen and then the pag...
jimbof
Mar 26, 2013Aspirant
Just seen the latest few posts, so had already taken things into my own hands, backed up everything overnight and have just performed a factory reset.....still getting the same issue and just seeing the readynas logo, a swirling circle hour glass and "Dashboard 1.0.0264" (same as before)
Now SSH is no longer enabled so can't run the above logs or change anything. Not really wanting to enable SSH just in case I have to use Netgear technical support but if someone has any great ideas then happy to try anything out!!
Also, as I said originally, all functionality seems to be working fine and "browsing" from RAIDar works fine
Ideas? it's running Firmware 5.3.7. I can only think it's something to do with my pc's (tried it on 3 different computers with firewalls/antivirus etc all disabled, one has a completely fresh install of Win 7)?
