jimbof
Mar 24, 2013Aspirant
Dashboard/Frontview not working
Hello, I've been running a Duo v2 for the past 6 months with all running smoothly but today I can't access the main dashboard :( I put in the correct IP address, get the login screen and then the pag...
jimbof
Mar 27, 2013Aspirant
Solved (well found the cause!) - had a brainwave this morning that it couldn't be the Duo that was the problem as I'd factory reset multiple times and tried different disks, so the only other thing that's changed on all my PCs since the last time Frontview worked is Internet Explorer 10....bingo, uninstalled and it's now working.
Just serached for this in the forums and it seems only a few people have had the same issue and all back last year (when I guess IE10 would have been a beta or in Windows 8)
I know the simple solution is use Firefox, Chrome etc... but that's not really a proper fix. Is there someting I should adjust in IE10 to get Frontview to work or will their be an update to fix this compatability issue?
