jimbof
Mar 24, 2013Aspirant
Dashboard/Frontview not working
Hello, I've been running a Duo v2 for the past 6 months with all running smoothly but today I can't access the main dashboard :( I put in the correct IP address, get the login screen and then the page goes to the loading Dashboard page (version 1.0.0.264) but never progresses on from that. Everything else seems to be working ok, I can access files normally from networked computers, can SSH into the Readynas, can run Logitech media server etc... Any ideas :?
I've been reading other posts so have already tried updating the firmware (it was already running 5.3.7 but re-installed) via SSH (complete novice with this type of access, so just following other posts on how to do it!!). Here's the results from:
Any help would be really appreciated
Many thanks in advance :D
# df -h
# tail /var/log/frontview/error.log
# cat /etc/default/services
# cat /etc/frontview/addons/addons.conf
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 855M 3.0G 23% /
tmpfs 16K 0 16K 0% /USB
/dev/c/c 1.8T 776G 1.1T 43% /c
[Sun Mar 24 10:50:56 2013] [error] [client 192.168.0.248] user admin: authentication failure for "/admin/": Password Mismatch
[Sun Mar 24 10:51:00 2013] [error] [client 192.168.0.248] File does not exist: /frontview/dashboard/images/scroller/style1-lr.png, referer: https://192.168.0.249/admin/
[Sun Mar 24 10:51:00 2013] [error] [client 192.168.0.248] File does not exist: /frontview/dashboard/images/scroller/style1-tb.png, referer: https://192.168.0.249/admin/
[Sun Mar 24 10:52:15 2013] [notice] Graceful restart requested, doing restart
apache-ssl: Could not reliably determine the server's fully qualified domain name, using 192.168.0.249 for ServerName
[Sun Mar 24 10:52:20 2013] [notice] Apache/2.2.16 (Debian) mod_ssl/2.2.16 OpenSSL/0.9.8o DAV/2 Axis2C/1.6.0 mod_apreq2-20090110/2.7.1 mod_perl/2.0.4 Perl/v5.10.1 configured -- resuming normal operations
[Sun Mar 24 11:19:45 2013] [warn] pid file /var/log/frontview/apache-ssl.pid overwritten -- Unclean shutdown of previous Apache run?
[Sun Mar 24 11:19:46 2013] [notice] Apache/2.2.16 (Debian) mod_ssl/2.2.16 OpenSSL/0.9.8o DAV/2 Axis2C/1.6.0 mod_apreq2-20090110/2.7.1 mod_perl/2.0.4 Perl/v5.10.1 configured -- resuming normal operations
[Sun Mar 24 11:20:23 2013] [error] [client 192.168.0.248] File does not exist: /frontview/dashboard/images/scroller/style1-lr.png, referer: https://192.168.0.249/admin/
[Sun Mar 24 11:20:24 2013] [error] [client 192.168.0.248] File does not exist: /frontview/dashboard/images/scroller/style1-tb.png, referer: https://192.168.0.249/admin/
USER_HOME_DIRECTORY=1
USER_HOME_DIRECTORY_FTP=0
USER_HOME_DIRECTORY_NFS=0
USER_HOME_DIRECTORY_RECYCLE=1
USER_HOME_DIRECTORY_RECYCLE_MAX_DAYS=0
USER_HOME_DIRECTORY_RECYCLE_MAX_SIZE=25000
DISALLOW_PASSOWRD_CHANGE=0
SAMBA=1
NETATALK=0
PROFTPD=0
RSYNC=0
APPGENIE=0
UPNP=1
APACHE=1
NFS=0
NFS_THREADS=1
HTTP_WEBSERVER_SHARE=
HTTP_WEBSERVER_SHARE_USE_PASSWORD=0
HTTPS_PORT=0
UPNPAV=0
READYTIVOD=1
BONJOUR=1
BONJOUR_AFP=1
BONJOUR_FRONTVIEW=1
BONJOUR_PRINTER=0
SNMPD=0
SNMP_ALLOW_HOST=
SNMP_COMMUNITY=public
SNMP_TRAP_DESTINATION=
ATALKD=0
AUTO_CHECK_UPDATE=1
BONJOUR_SUPPORT=1
CSV_USERADD_SUPPORT=1
DAAPD_SUPPORT=1
DAAPD=0
DISABLE_USB_SYNC=1
DISKCACHE=1
DOMAIN_SUPPORT=1
ENABLE_POWERON_TIMER_SUPPORT=1
FLASH_AUTO_COPY=0
FLASH_OWNER=admin
FLASH_PATH=Pictures
FLASH_SHARE=media
FTP_PORT=21
JOURNAL=ordered
LANGUAGES_SUPPORTED=en-us/utf-8,ja/utf-8,ko/utf-8,zh-cn/utf-8,zh-tw/utf-8,ru/utf-8,es/utf-8,pt/utf-8,de/utf-8,fr/utf-8,it/utf-8,nl/utf-8,pl/utf-8,cs/utf-8,sv/utf-8
LANGUAGE=en-us
MONITOR=board_temp,fan,disk_full,quota_exceeded,disk_temp
NTPDATE=1
RESYNC_UNCLEAN_SHUTDOWN=1
RSYNC_SUPPORT=1
SHAREACCESS=SAMBA,NETATALK
SHUTDOWN_ON_DISK_OVERTEMP=1
SNMP_SUPPORT=1
SNMP=1
SSHKEY=rsa
UDHCPD=0
UPNP_SUPPORT=1
UPNPAV_SUPPORT=1
WIZD=0
WIZD_SUPPORT=0
READYNASREMOTE=1
LEAFP2P=1
READYDROP=0
WINBIND=0
NOFLUSHD=5
READYNASVAULT=0
RAID_MODE=1
ENCODE=utf-8
SUPPORT_UTF8_NAMES=1
ALLOW_UTF8_NAMES=1
FTP_MODE=anonymous
TEMP=0,0,0
FAN=1,0,0,0,0
SMTP_PROVIDER=Internal
SQUEEZEBOX=1
ENABLE_POWERON_TIMER=1
SSH=1
WAKE_ON_LAN=0
UPSConfig=,0,,0,,0,,,
ENABLE_REMOTE_UPS=0
ENABLE_SNMP_UPS=0
UPS_LOWBATT_PCT=
HTTPS_SSL_KEY_HOST=192.168.0.249
READYNAS_PHOTOS_II_SUPPORT=1
READYNAS_PHOTOS_II=1
AUTOMATIC_VOLUME_EXPANSION=1
SQUEEZEBOX!!Logitech Media Server!!7.7.2!!/etc/frontview/addons/bin/SQUEEZEBOX/start.sh!!/etc/frontview/addons/bin/SQUEEZEBOX/stop.sh!!Other!!detail_url==http://www.logitech.com/speakers_audio/wireless_music_systems::icon_url==/addons/SQUEEZEBOX/icon.png
READYNAS_PHOTOS_II!!ReadyNAS Photos II!!1.0.6!!/etc/frontview/addons/bin/READYNAS_PHOTOS_II/start.sh!!/etc/frontview/addons/bin/READYNAS_PHOTOS_II/stop.sh!!Other!!current_url==http://www.readynas.com/download/addons/arm/current/READYNAS_PHOTOS_II_CURRENT.xml::detail_url==http://www.readynas.com/photos2
DAAPD!!FireFly!!1.0.3!!start-stop-daemon -S -q -x /usr/sbin/mt-daapd!!start-stop-daemon -K -n mt-daapd
- StephenBGuru - Experienced UserYou could try this: http://techathlon.com/internet-explorer ... lity-mode/
- wauguxxAspirantI tried to connect my Ready NAS to my desktop directly and still nothing happened, i was unable to access the dashboard? I tried the default ip of 192.168.168.168. I will try to connect it to another computer and see what happens.
- StephenBGuru - Experienced UserIt might be less confusing if you create your own thread.
- cakeeAspirant
StephenB wrote: You could try this: http://techathlon.com/internet-explorer-10-run-compatibility-mode/
Thanks very much,it works.
