getads
Dec 28, 2015Aspirant
Data Degraded but Volumes are fine?
Hi there, I've had a ReadyNAS 314 taking care of my Time Machine backups for around 2 years now with no problems. Currently, the ReadyNAS LED is flashing "data ; Degraded" so I had a look ins...
- Dec 28, 2015
If you hover your mouse over the disk you should see some stats.
Your logs show that disk 3 (one of your WD20EARS disks) has failed. It has 945 reallocated sectors and a current pending sector count of 695. I would suggest replacing this e.g. with a WD20EFRX.
Your smart_history.log would suggest this disk was failing possibly as far back as April. Certainly by May/June.Do you have a backup?
Dec 28, 2015Guru - Experienced User
Degraded means there is no raid redundancy, so any disk failure will result in loss of the volume.
How many volumes do you have? (with xraid you'd only have one).
