getads
Dec 28, 2015Aspirant
Data Degraded but Volumes are fine?
Hi there, I've had a ReadyNAS 314 taking care of my Time Machine backups for around 2 years now with no problems. Currently, the ReadyNAS LED is flashing "data ; Degraded" so I had a look ins...
- Dec 28, 2015
If you hover your mouse over the disk you should see some stats.
Your logs show that disk 3 (one of your WD20EARS disks) has failed. It has 945 reallocated sectors and a current pending sector count of 695. I would suggest replacing this e.g. with a WD20EFRX.
Your smart_history.log would suggest this disk was failing possibly as far back as April. Certainly by May/June.Do you have a backup?
