davidbonnici
Dec 19, 2016Aspirant
Data is not accessible after pluging the 4th HD and upgrading to fw 6.6.0 due to "mv_xor_status+88"
I bought the 4th hard drive today WD Red 4TB. I got another 3 HD plugged already WD Green 4TB. I'm using X-Raid and it was setup as Raid5. After 6% of the re-syncing process NAS Admin was not accessi...
davidbonnici
Dec 20, 2016Aspirant
I sent the logs by email as instructed. Hopefully to get your insight sooner or later. It is still synching as we speak.
mdgm-ntgr
Dec 20, 2016NETGEAR Employee Retired
There are problems mounting your volume. I can see that your volume is extremely full.
Perhaps you could try booting into volume read-only mode (a boot menu option).
Do you have a backup?
- davidbonniciDec 21, 2016Aspirant
Resyncing is complete. I rebooted the NAS and the volume is now appearing again
I have 4x4TB now but it seems like that the new HD is not taken altough it's online. What should I do? Should I remove it and insert it again?
I just proceeded, I turned off the NAS again, removed the 4th HD and when it booted up the status went to DEGRADED. I plugged again the 4th Hard Drive and now it is re-syncing again. This is very odd, I mean I expected that new HD will increase the total capactiy. Let's say it at least I have the data.
What are your recommendations?Thanks a lot!
Best Regards
David Bonnici
- StephenBDec 21, 2016Guru - Experienced User
Sometimes the NAS makes the added disk a "spare" - I don't understand the mechanism for that choice.
You won't see the volume expansion until the end of the resync, so for now you need to wait.
