eluLab
Apr 12, 2018Aspirant
Data Recovery readyNAS 2304
Hi Guys, we used to use a RN2100 which stopped working after we tried to shut it down. we've never got it running again. The netgear support suggested that we buy a ReadyNAS 2304. So we did and put...
- Apr 12, 2018
eluLab wrote:
okay - i see. wonder why the support guy told me to go that way. -.-
It definately rund RaidiatorThis process should have worked then: https://kb.netgear.com/29957/ReadyNAS-Migrating-disks-from-RAIDiator-4-2-to-ReadyNAS-OS-6-x86
Can you access the admin web ui of the NAS, and post a screenshot of what you see there?
mdgm-ntgr
Apr 12, 2018NETGEAR Employee Retired
Volume read-only mode is a boot menu for volumes created on OS6, not for data recovery attempts of volumes from a system running RAIDiator.
- eluLabApr 12, 2018Aspirant
It definately rund Raidiator- StephenBApr 12, 2018Guru - Experienced User
i started a test disk procedure which lead to nothing but flashing red lights on the disks. Can i exit that procedure or does it lead to data loss?
If i can exit it i can restart the machine and enter the web ui and post screenshots
