eluLab
Apr 12, 2018Aspirant
Data Recovery readyNAS 2304
Hi Guys, we used to use a RN2100 which stopped working after we tried to shut it down. we've never got it running again. The netgear support suggested that we buy a ReadyNAS 2304. So we did and put...
- Apr 12, 2018
eluLab wrote:
okay - i see. wonder why the support guy told me to go that way. -.-
It definately rund RaidiatorThis process should have worked then: https://kb.netgear.com/29957/ReadyNAS-Migrating-disks-from-RAIDiator-4-2-to-ReadyNAS-OS-6-x86
Can you access the admin web ui of the NAS, and post a screenshot of what you see there?
eluLab
Apr 13, 2018Aspirant
After a few detours we found out that this process did work!
Thanks for the hint!
We're backing up the data right now.
Thanks a lot for the help!
mdgm-ntgr
Apr 15, 2018NETGEAR Employee Retired
How did the backup go?
- eluLabApr 16, 2018Aspirant
no issues (except for minor owner/user/group rights hassle). We used Carbon Copy Cloner to get everything off the machine. Due to read-only there's no syncing option so we had to manually keep track of unscopied files. But we did that, updated the machine to OS6 and at the moment we're copying the data back on the NAS.
