gingernut63
Sep 29, 2011Aspirant
Date/timestamp issue on Music Players
Have searched the forum on this and really haven't found one gives the required answers. I use MediaMonkey to update the tagging of my audio files which are stored on a ReadyNAS Duo running 4.1.8. ...
reddinazz
Jul 02, 2012Aspirant
I have already posted this information to the MediaMonkey forum. But it should go here as well:
No, I am still using MM 4.0.3.1476 and according to MM developer information the workaround has been implemented in build 1601.
Although late (too late for you), it seems Netgear did it.
PS: Just found out how to read out the samba version (see http://www.readynas.com/forum/viewtopic.php?f=17&t=62461). Firmware 4.1.9 is using smbd version 3.5.15
If you are using a latest MediaMonkey beta then the fix might not be Netgears!
