brettgavin
Oct 30, 2012Tutor
Dead Disk replacement - Volume Dead #19774843
Hi, Is there any way to manually recover a dead volume? I have a Pro6. Disk #1 died. I replaced the disk. During the resync, disk #6 died. I removed and reseated disk #6. About a minute later, ...
mdgm-ntgr
Oct 30, 2012NETGEAR Employee Retired
Should add that when a disk is replaced it puts heavy stress on all disks as the disk has to be synced sector by sector. So if a second disk is failing the resync can finish it off.
If you hadn't removed and reseated disk 6 data recovery chances would have looked a lot better. Hopefully disk 6 hasn't been wiped but it sounds like it probably has
