brettgavin
Oct 30, 2012Tutor
Dead Disk replacement - Volume Dead #19774843
Hi, Is there any way to manually recover a dead volume? I have a Pro6. Disk #1 died. I replaced the disk. During the resync, disk #6 died. I removed and reseated disk #6. About a minute later, ...
mdgm-ntgr
Oct 31, 2012NETGEAR Employee Retired
You may wish to download your logs (Status > Logs > Download all Logs) and attach them to your case if you haven't already.
It's normal for access to data to be slow during a resync. Remember all the disk are under heavy stress from the resync.
If (and only if) you have SSH access check to make sure the OS partition has plenty of free space before downloading the logs.
What brand and model disks do you have installed?
# df -h
