garyd9
Sep 16, 2014Virtuoso
dedicating 2nd ethernet port for backups.. how?
Using a pair of 516's (or any two readynas devices with dual ethernet), is there a way to use the second ethernet port for a direct connect to the second NAS for only backups? For example, I have t...
Sep 17, 2014Guru - Experienced User
If you turn on user access to the snapshots, then they will be included in the backup unless you exclude it. That's generally not a good thing, since if you copy a single snapshot you end up doubling the storage needs, and usually there are a lot of snapshots.
garyd9 wrote: ...Actually, I'm going to have to do some searches to find out if OS6 supports any type of snapshot backups at all...
btrfs itself puts the unchanged files into multiple folders (e.g. the snapshots and the main share) - so each snapshot appears to be a full copy of the share. This is a bit like a link, but it doesn't show up as a link. So if you back up or copy a snapshot, you are copying the complete share as it existed when the snapshot was made - not a delta.
