TheCHIMP_net
Dec 25, 2008Aspirant
Default Admin/Netgear1 Logon Doesnt Work (#8463338)
Hello Forum
Long time reader, finally got the ReadyNas Duo 2150 for Chirstmas today! Very excited and was already planning my "wow, this set up incredibly easy" post of recommendation when I got to the logon stage after installing RaidAR.
Included Documentation Says Default Logon: admin Password:netgear1
Does not work.
Other suggested solutions mentioned on these boards that have not succeeded:
Tried from a vista and an XP machine, on firefox and IE - did not work
Uninstall RAIDar and Reinstall - did not work
Tried password "infrant1" instead of "netgear1" - did not work
Tried logging on directly to the 'IP address'/admin - did not work
Tried using "computer name" in place of "admin" -- did not work
Please, wise ones, I want to use the new NAS. How can the factory default password and logon be incorrect?!?
Does not work.
- chirpaLuminaryIt will be admin/infrant1 or admin/netgear1. There is no other default possibility. If those still don't work, then I'd look at another computer/browser/disable proxy/virusscanner/etc.
viewtopic.php?f=9&t=16694 - ewokNETGEAR ExpertA couple of other (possibly stupid) suggestions:
1. Make sure you did the factory default correctly. If RAIDar is not asking you to setup the NAS a couple of minutes after initiating the factory default, then you haven't done it correctly.
2. Did you do the factory default before or after you upgraded the drives? You need to do it after the drive upgrade. - TheCHIMP_netAspirantChirpa: Thanks...
Neither logon/pw combo works (or has worked)
and even disablilng antivirus hasnt worked either...
have "reset" the NAS using the paper clip in the back 4-6 times too and repeated the above steps. - chirpaLuminaryWould you be willing to setup remote access for us, so we could connect to it and check it out more deeply?
EWOK, thanks for caring and checking in: Can you explain "upgrade the drives"? I did install my own new, compatible, 2X 1TB identical drives straight away right out of the box. I did this before even powering on the NAS for the first time and attempting the first set up. - dbott67GuideI *think* he's asking if you did this after installing the new hard drives:
faq.php#How_do_I_reset_the_ReadyNAS_to_factory_default%3F
-Dave - ewokNETGEAR Expertdbott67 is correct. You said you've done several factory defaults already, so that must mean the factory defaults were with the 1TB drives in there.
Not sure what else could be the problem. It's probably best for one of us to look at the NAS remotely. - TheCHIMP_netAspirantSOLVED!!
I cant believe it....this is so random.
I zoned out watching TV while holding in the paper clip to hard reset and this time after 3-4 minutes, the NAS booted up in a different way than ever before. It took 10-20 minutes of "provisioning" time (my term, not a technical term seen anywhere) and then I was able to use the provided Netgear default login and password
admin/netgear1
To those who go after me, a few tips.
Keep the paper clip in for a long time
Watch the RAIDar screen all the way to the right and it will tell you what stage of the format it is in, this took about 20 minutes until I could even log in to the NAS
Once logged in, it immediately started mirroring my 2nd drive to match the first. Even though the first drive was empty, it still took this time to "sync" the drive. As they are both 1TB drives, it took 3+ hours to sync the drives even with nothing on them. I left it on overnight and it was done in the morning.
Thanks to Ewok, Chirpa, DG, and the Netgear techs...saviors. - ewokNETGEAR Expert
If you weren't getting the "provisioning" time in your previous factory default attempts, you were probably doing a firmware reinstall instead, which doesn't reset the password. I'm glad you were able to figure it out. :D - dhs100AspirantI would be VERY interested to know if you found a solution. I'm having the exact same problem...really, really annoying.
