pteittinen
Feb 16, 2011Aspirant
Delayed write to ReadyNAS Pro failed
Online tech support case #14688578. My RNPro worked fine for quite a while on 4.2.15, but now I can't write large files on it anymore. Two days ago RNPro ran a scheduled volume consistency check...
mdgm-ntgr
Feb 16, 2011NETGEAR Employee Retired
Is this a Pro Business Edition or a Pro Pioneer?
If you have the Pro Business Edition snapshot space is set using RAIDar after a factory default (wipes all data, settings, everything) or on initial setup. If you don't choose to have no snapshot space, a small amount (10GB, I think) will be allocated automatically. Snapshot space cannot be resized at this time.
If you have the Pro Pioneer there is no snapshot feature in Frontview and 10GB (I think) is allocated for snapshots for use with the Online Filesystem Check.
If there is no snapshot space allocated you shouldn't be able to run the Online Filesystem Check.
