pteittinen
Feb 16, 2011Aspirant
Delayed write to ReadyNAS Pro failed
Online tech support case #14688578. My RNPro worked fine for quite a while on 4.2.15, but now I can't write large files on it anymore. Two days ago RNPro ran a scheduled volume consistency check...
pteittinen
mdgm wrote: Is this a Pro Business Edition or a Pro Pioneer? If you have the Pro Pioneer there is no snapshot feature in Frontview and 10GB (I think) is allocated for snapshots for use with the Online Filesystem Check. If there is no snapshot space allocated you shouldn't be able to run the Online Filesystem Check.
It's a Pro Pioneer, but I'm fairly certain I have seen snapshot feature listed in Frontview. Can't check now, since I rebooted the box with volume check enabled and it's going to take a while until I have access to it. I'll verify once Frontview becomes available.
