pteittinen
Feb 16, 2011Aspirant
Delayed write to ReadyNAS Pro failed
Online tech support case #14688578. My RNPro worked fine for quite a while on 4.2.15, but now I can't write large files on it anymore. Two days ago RNPro ran a scheduled volume consistency check...
falco1
Nov 03, 2011Aspirant
I know this is an old thread but I am having exactly the same problem as OP.
ReadyNas Pro Pioneer
The error I am getting is "Windows Delayed Write Failed, This error may be caused by a failure of your computer hardware or network connection. Please try to save this file elsewhere"
This error occurs when I try to write large (greater than approx 2Gb) files to the ReadyNAS.
Any suggestions on what I do to fix this problem.
This ReadyNAS has worked ok up until the last Firmware update
