rhaisinger
Nov 09, 2013Aspirant
Detected increasing command timeouts after move to 4.2.24
Hi I've encountered the following message on each of my 3 drives in a ReadyNAS Pro immediately after making the move to 4.2.24. Error message fires every few minutes. Detected increasing comma...
rhaisinger
Thanks - waiting patiently for a response from support while sweating and hoping that this doesn't end really badly. :-\
I'm using Chrome Version 30.0.1599.101 m I also have IE 10 installed but don't really use it much.
I can't seem to attach an image but the little popup I get in FrontView (when I click on Volume in the Navigation bar) reads very simply:
No volume exists. Some menu options are available only if a valid volume exists.
I just tried to access the shares and they actually show up when I hit the device - all of the root level shares appear but I can't seem to navigate into any of the folders.... I try to enter the folder and it just times out and then I get a Windows Network Error saying that it can't access the folder.
