Swervey
Apr 16, 2016Aspirant
Detected increasing pending sector
All Hope someone can advise on the issue i'm getting. I have a 4 bay readyNAS and been running 4 disks for a while. Recently i've had a number of errors come up: Detected increasing pendi...
vandermerwe
Apr 16, 2016Master
Those disks are not on the compatibility list and many users have problems with them. Are all 3 disks the same model?
I would suggest testing all 3 disks using vendor tools (WD lifeguard) first.
Do you have a backup of the data on the readynas? It doesn't sound like it.
- StephenBApr 16, 2016Guru - Experienced User
These are all old disks, correct? The wd20ears was discontinued by WDC in 2011.
They do work in RAID (I have 4 in my NV+) but you really should use new drives in your NAS. I'd recommend WDC Red drives (2 TB model is WD20EFRX).
