steveoelliott
Dec 24, 2015Luminary
device eth0 entered promiscuous mode
Hi all,
I noticed something strange in my logs today, it never appears to have happened (certainly since March) before.
Dec 17 09:15:57 despair kernel: device eth0 entered promiscuous mode
Dec 17 09:16:02 despair kernel: device eth0 left promiscuous mode
And then...
Dec 22 14:58:26 despair kernel: device eth0 entered promiscuous mode
My device is currently in Promiscous mode too, it has not left it since.
I was not logged into the device via Web or SSH around this time and I had a look at the last logins to check nobody else had gained access. I am just curious what's going on and what may cause the interface to switch to promiscous mode. Normally only TCPDUMP causes this to happen.
I did also check running processes, I find this one a little odd:
avahi-daemon: running [despair.local]
Thanks...
- Marto731Aspirant
Steve,
For clarity, can I get the following.?
NAS model no & Firmware.
The switch it is connected to
Is there a 2nd Eth cable connected to NAS?
I would like to rule out teaming.
Thanks, Marto
- steveoelliottLuminary
Something on the network must be triggering this! I see the following on the secondary device I have on this LAN:
Dec 17 09:15:57 chaos kernel: device eth0 entered promiscuous mode
Dec 17 09:16:02 chaos kernel: device eth0 left promiscuous mode
Dec 22 14:58:26 chaos kernel: device eth0 entered promiscuous modeThey are connected to Cisco small business switch SD108.
No 2nd interface.
No changes have been made.
Both are ReadyNAS Pro 6 running 4.2.28.
I'm just curious as to why this should occur and also what this avahi daemon thing running is. Probably not related.
avahi does Apple discovery (bonjour or rendezvous). https://en.wikipedia.org/wiki/Avahi_(software)
