mrputtputt's avatar
Jun 25, 2024
did my readynas duo v2 finally die?
i got this used in 2011 from an acquaintance. Since I bought 2 new drives (WD red) in 2012 since one drive went kaput and I wanted to keep the same model drives. I had issues before where power outag...
  • StephenB's avatar
    Jul 01, 2024
    mrputtputt wrote:
    I reformatted my 3.5" drive and it's usable in windows 11. But then i plug it into the NAS, i still get the same beeps. Time to call it quits and declare it dead?
    I still am wondering if it is the disk.  The NAS has no speaker, so it actually can't beep - all it can do is flash the LEDs.  If you are hearing beeps, they are coming from the disk - which is not a good sign.  WD says to replace the disk if you hear them. But this could also indicate a power problem, especially if you don't hear them when they are connected to the PC.  Still, the very slow formatting time in Windows suggests the disk isn't very healthy.
    So I think the three possible causes remain on the table:
    • failed disk
    • power issue with the adapter
    • failed chassis
    But I think it does make sense to move on.
    Personally, I am going to run my own Duo v1 (and NV+) as long as they work.  But I won't spend much (if anything) to fix them when they eventually fail.  My primary storage and backups are hosted on newer, faster NAS, these two are only used as secondary backups.
    That said, you could alternatively do a risk buy of a compatible power adapter, and/or a replacement disk.  Total US cost would be around $125 (assuming a 2 TB purchase).  The disk could be used in the new NAS if this fails, so the risk is only the cost of the power adapter.
ProSupport for Business
