heideroffset
Mar 15, 2023Aspirant
Different network speed on shares, same NAS, ReadyNas 104
We have a ReadyNas 104 with multiple shares. All shares have the exact same settings. Some of the share folders are extremely slow, some work fine. I have confirmed this with NASTester - some shares ...
Mar 15, 2023Guru - Experienced User
heideroffset wrote:
Strangely, if I run the same test on its IP \\192.168.0.128 it's way faster than over the local name \\PIWI-1
Do you have ipv6 enabled on the NAS? If you do, try disabling it.
heideroffset
Mar 16, 2023Aspirant
ipv6 and strict sync are disabled on all shares
- StephenBMar 16, 2023Guru - Experienced User
a bit confused on the first bit, since ipv6 is not a per-share setting.
What firmware are you running?
Is the PC connected with ethernet or wifi?
Also, I am wondering what results you get with strict sync enabled.
