jetheroheller
Feb 19, 2016Tutor
Difficulty using double-click and shift-click in OS6 admin console shares tab
I've got a strange problem and I'm wondering what I can try to resolve it.
I have two computers, both running windows 10, both running chrome, using the same user profile, connected to the admin console of my netgear RNDU600+ running OS6.
on one computer, in the shares section of the admin console, I can double-click in the details display to open a share, and I can shift-click to multi-select. yay.
on the other computer, double-click just opens the OS6 context menu, while shift-click just selects the new item and unselects the original item.
Any idea how I can use mutli-select and shift-click on both computers. Any configuration changes I should look at?
The only related forum post I could find was from 2013, where StephanB was asking about the chrome download settings. I'll take a look at that.
user ledridge on this post seems to have the same issue as me
- mdgm-ntgrNETGEAR Employee Retired
Which version of Windows on each PC?
Which web browser and version on each PC? Have you tried multiple different web browsers?Which firmware version is running on the NAS?
Thank you so much for taking my question!
Let's call a the one that works, b the one that doesn't.
a) WIndows 10 Pro 1511 10586.104 64bit, no pen or touch (Sony)
b) Windows 10 Home 1511 10586.71 64bit, 10 point touch support (Dell)
Which web browser and version on each PC? Have you tried multiple different web browsers?a) chrome Version 48.0.2564.116 m
b) chrome Version 48.0.2564.116 m
I will try multiple browsers and report back
6.4.2
Also, realized one is touch-screen enabled, though I'm not using it I'm using a mouse. Perhaps that is related. However double-click and ctrl-click / shift-click work fine in windows explorer.
