StarshipUK
Dec 08, 2015Aspirant
Disable Automatic Recycle Bin on ReadyNas 102
I have a ReadyNas 102 and am using 3rd party backup software and the default Backup Folder on the NAS box. The problem is everytime it creates a new backup it is putting the old one into a Automa...
siigna
Dec 08, 2015NETGEAR Employee Retired
Recycle bin for SMB shares was never enabled in the ReadyNAS OS 6.x firmwares. Is that folder possibly being created by the backup software? Was recycle bin possibly enabled previously from the ReadyNAS back-end?
- StarshipUKDec 08, 2015Aspirant
If I copy a file on that folder or one of the other folders, such as Documents and then delete it, the NAS box is then creating a directory called Recyle Bin in that folder with the deleted file inside it.
The backup software is not good enough to create a recycle bin itself.
- siignaDec 08, 2015NETGEAR Employee Retired
Definitely sounds like it got enabled from the back-end, then.
Mind making a config backup of your NAS (System > Settings > Configuration Backup) and sending it over (attn: siigna)?
