StarshipUK
Dec 08, 2015Aspirant
Disable Automatic Recycle Bin on ReadyNas 102
I have a ReadyNas 102 and am using 3rd party backup software and the default Backup Folder on the NAS box. The problem is everytime it creates a new backup it is putting the old one into a Automa...
StarshipUK
If I copy a file on that folder or one of the other folders, such as Documents and then delete it, the NAS box is then creating a directory called Recyle Bin in that folder with the deleted file inside it.
The backup software is not good enough to create a recycle bin itself.
siigna
Dec 08, 2015NETGEAR Employee Retired
Definitely sounds like it got enabled from the back-end, then.
Mind making a config backup of your NAS (System > Settings > Configuration Backup) and sending it over (attn: siigna)?
