IGY's avatar
IGY
Disabled network interface (Eth1) after firmware 6.9.1 on RN212
After upgrade to 6.9.1 on the the ethernet adapter appears disabled.
They were bonded prior to upgrade. Deleted the bond, but eth1 appears disabled.
Also cannot re-bond again.
Went back to 6.9.0, but the same. Upgraded to 6.9.1 and no change.
Need to enable back the second adapter.
    • IGY's avatar
      IGY
      Managed to activate it by un pluging the main Eth0 cable, restart NAS on Eth1 only and then once active plugged second cable as well.
      Also successfully created NIC Team (Bond).
      So fixed! Was just about to do the OS reinstall as well but not necessary now. :)
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Hi IGY
    Thank you for sharing your resolution and/or workaround. We appreciate your contribution to the community.
    Feel free to post any suggestions, questions, recommendations or anything about your NAS that you think needs attention or will help others.
    Regards
ProSupport for Business
