BJB
Jul 21, 2023Aspirant
Disk 1 of 4 failed on RN424, degraded - Rebuild Steps?
StephenB Greetings! You have helped me many times in the past and I have had many good years with my units. Today I got the dreaded email that Disk in channel 1 changed state from online to faile...
- Jul 21, 2023
BJB wrote:
I am in the process of ordering another Seagate Ironwolf 10TBdrive same model and size of the one that failed. Although the model number varies a bit due to this being newer I assume? FWIW I had a ST10000VN0004 and now it is a ST10000VNA00. I think it relates to platter number and density but couldn't find definitively. I assume it is okay to use.
It should be fine.
BJB wrote:
However there might be a few other files on there that are not on another backup. Should I copy these somewhere before the rebuild or does that put stress on the remaining drives? Or can I copy during the rebuild or should I just let it rebuild first?
You can copy those off first.
Data blocks on the missing disk will be reconstructed on the fly from the others. That is the same process that is done during the rebuild, but not as stressful because it uses a lot less data.
BJB wrote:
Today I got the dreaded email that Disk in channel 1 changed state from online to failed on my RN424. The light on that drive was red, and when I logged into the NAS the main page said "healthy" but degraded.
Can you please tell me the correct way to rebuild? My NAS is currently off. Just put the new drive in and turn on? Or boot it up first and THEN take out the drive and replace?
You can use either procedure - both hot swapping the drive when the NAS is running, or swapping when powered down will work. The NAS detects the removal/insertion directly when hot-swapping, so there is no chance it will be confused. On the other hand, if you were to accidently remove the wrong drive with the NAS running there would be a problem -so you need to be careful not to make that mistake. That's not a concern with the NAS powered off (as long as correct drives are installed when you power up). The NAS will still figure out what changed, as the new drive is blank/unformatted.
Though since you have some files you want to back up, I suggest
- removing the failed drive while the NAS is powered down
- booting up with bay 1 empty, and copying off the files
- hot-insert the new disk into the empty bay.
No chance of accidentally hot-removing one of the remaining drives, since you are only hot-inserting.
Also, if you can connect the new disk to a PC (either SATA or with a USB adapter/dock) then I recommend testing it with Seatools before putting it into the NAS. I generally run the full "long" test, and follow that up with the full "erase" test. I've had a couple of new out-of-the-box disks that passed one of these tests and failed the other. It will take some time (maybe two days to run both), but I like to be sure that the new disk is working ok before I put it into the NAS. Don't format the drive in the PC - Seatools will find the drive and test it unformatted.
Sandshark
Jul 28, 2023Sensei
Four days and the test hasn't even completed seems to indicate it's running into a lot of errors. On my PC, testing a 10TB drive takes about 12 hours.
BJB
Jul 28, 2023Aspirant
Interesting. I had read somewhere that for a USB enclosure this seemed about right. I am running a USB enclosure on an average computer. 10TB drive.
Perhaps yours was with an internal SATA connection?
I guess I will know in 4 days?!
BJB
- StephenBJul 28, 2023Guru - Experienced User
Four days is definitely a lot longer than I've seen.
Is the enclosure (or the PC port) USB-2? That would explain it.
- BJBJul 28, 2023Aspirant
I should have done this from the jump. I connected the drive to the motherboard and it is completing about 10% an hour!. And I bet you are right, although the enclosure was USB the port may not have been.
Thanks,
BJB
- BJBJul 31, 2023Aspirant
StephenB ,
Both tests ran successfully, and I followed your instructions exactly. All went well and volume is resynch'd. Thanks again for all your help!
And thanks to you for nudging me to connect the drive directly to an internal SATA connection. Your time estimate was spot on, basically a day for each test.
Thanks,
BJB
- StephenBJul 31, 2023Guru - Experienced User
BJB wrote:
StephenB ,
I'm glad we were able to help.
