puds
Nov 26, 2013Aspirant
disk 2 failure on pro
ok i have a dead disc in my r/nn pro . it is saying it is dead . the unit is 96% full .. can i replace (add) a drive with with bigger space say 2/3tb . could i replace it with something like this Tosh...
Nov 26, 2013Guru - Experienced User
Well, you definitely need more space.
If you are still in warranty (5 years for business models) you should choose something from the HCL - otherwise you will lose support.
Note you would need at least 2 of the larger drives to get any more space in a RAID volume.
What firmware are you running?
