puds
Nov 26, 2013Aspirant
disk 2 failure on pro
ok i have a dead disc in my r/nn pro . it is saying it is dead . the unit is 96% full .. can i replace (add) a drive with with bigger space say 2/3tb . could i replace it with something like this Tosh...
Nov 27, 2013Guru - Experienced User
Relevant text is here:
You have two failing disks, not one.
(1) usually pending sector counts are worse than ATA errors.
(2) If disk 2 is the disk removed from the array, it is possible that resync will fail when because of the pending sector errors on drive 1.
Make a backup of your data without delay - it is very possible that you will lose your data volume when you try to replace your disks.
puds wrote: Wed Nov 27 07:57:00 WET 2013 Detected increasing pending sector count[837] on disk 1 [ST31000340NS, 9QJ4C745]. This often indicates an impending failure. Please be prepared to replace this disk to maintain data redundancy.
Sun Nov 24 14:12:36 WET 2013 Newly added disk has failed SMART test on channel: 2 (/dev/sdb)
Sun Nov 24 13:55:13 WET 2013 Newly added disk has failed SMART test on channel: 1 (/dev/sda)
Sun Nov 24 12:54:24 WET 2013 Reallocated sector count has increased in the last day. Disk 2: Previous count: 4 Current count: 402 ATA error count has increased in the last day. Disk 2: Previous count: 0 Current count: 6 Growing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk.
