puds
Nov 26, 2013Aspirant
disk 2 failure on pro
ok i have a dead disc in my r/nn pro . it is saying it is dead . the unit is 96% full .. can i replace (add) a drive with with bigger space say 2/3tb . could i replace it with something like this Tosh...
Dec 31, 2013Guru - Experienced User
Do you have an up-to-date backup? If not, that should be the first priority.
Once that is done, I suggest that you check the drives with vendor tools on a PC (seatools for seagate, lifeguard for western digital).
