puds
Nov 26, 2013Aspirant
disk 2 failure on pro
ok i have a dead disc in my r/nn pro . it is saying it is dead . the unit is 96% full .. can i replace (add) a drive with with bigger space say 2/3tb . could i replace it with something like this Tosh...
Dec 31, 2013Guru - Experienced User
You can test the drives in a PC using the vendor tools. The file system can't be read, but the diagnostics don't care about that. The normal tests are non-destructive - there is a destructive write test in both diags, but you will be properly warned if you accidentally click on it.
