forestpct
Apr 18, 2015Guide
Disk drive failure in Readynas Duo V1 - Advice please
My old (but until now reliable) ReadyNas Duo V1 failed this morning. It's a 2 drive unit. It powers on but cannot be found on network by Raidar or Windows explorer. Have found that if I remove Disk ...
forestpct
Apr 22, 2015Guide
OK. Have confirmed that disk drive in slot 1 has failed. Have removed it and ReadyNas now powers on and is usable with jut the drive in slot 2 plugged in. It is a 750GB Seagate Baracuda ST350330AS. Have purchased a 1TB WD10EFRX as a replacment for disk 1 (which was also a 750GB Baracuda ST350330AS). Can you confim replacement procedure? Do I just plug the new 1TB drive in slot 1 and let the ReadyNas sync the 2 drives and re-establish the RAID redundancy? The ReadyNas firmware is at Raidiattor 4.1.14.
Thanks
Thanks
