forestpct
Apr 18, 2015Guide
Disk drive failure in Readynas Duo V1 - Advice please
My old (but until now reliable) ReadyNas Duo V1 failed this morning. It's a 2 drive unit. It powers on but cannot be found on network by Raidar or Windows explorer. Have found that if I remove Disk ...
RX
Apr 22, 2015Luminary
forestpct wrote: Can you confim replacement procedure? Do I just plug the new 1TB drive in slot 1 and let the ReadyNas sync the 2 drives and re-establish the RAID redundancy? The ReadyNas firmware is at Raidiattor 4.1.14.
Yup! You may insert the new 1TB drive into slot1 and it should automatically proceed with the resync process.
