tennisman
Feb 24, 2014Aspirant
Disk Full - Does old data purge??
Newly registered user. I am using the Duo v2 as a storage device for IP cameras that are run on an NVR. My question is; when the 3TB HDD gets full, what happens? My guess is that I will be notifi...
Mar 08, 2014Guru - Experienced User
How are you trying to access it to delete stuff? Are you able to run Frontview?
jamessawle wrote: I have just managed to fill mine totally, it is now 100% full, and now cannot access i to delete stuff, so it will carry on after reaching 90%, the only issue now is that without dumping the RAID and loosing all my data, I cannot access the RAID to dlete only the files that I no longer need to then be able to access the RAID again! not fun...
