gpaolo
Jan 13, 2020Luminary
Disk replacement - back sync and again degraded after reboot
Hi all, I am having some trouble with my RN524. I have 2x1TB and 2x4TB disks, each couple in RAID1 on my NAS. A few days ago, while I was away (bacause it always happens while I am away...) one of t...
- Jan 26, 2020
I have returned finally home and swapped the drives... and it works fine.
Oh well, problem solved, next time use more brain...
Thank you everyone, sorry for the mistake!
gpaolo
Jan 17, 2020Luminary
Ok now I feel completely stupid...
Device: sdc Controller: 0 Channel: 2 Model: WDC WD40EFRX-68WT0N0 Serial: WD-WCC4E3CJTH7N Firmware: 82.00A82W Class: SATA RPM: 5400 Sectors: 7814037168 Health data ATA Error Count: 7 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 29 Start/Stop Count: 110703 Power-On Hours: 35580 Power Cycle Count: 32 Load Cycle Count: 110942
I have indeed reinstalled the old disk.
I think I even know how it happened. I wasn't able to fix the disk in the plastic holder of the tray, so I put it back, removed the frame from the metal tray and when I got the disk back, I must have picked up the old one.
Oh and the other disk has similar power on hours... I think I'm going to switch off my NAS and keep it off until I come back home.
gpaolo
Jan 26, 2020Luminary
- StephenBJan 26, 2020Guru - Experienced User
I'm glad that all is well.
FWIW, it's easy to make mistakes when manipulating disks - that's one reason it's good to make sure your back up is up-to-date first.
