sparky_john's avatar
sparky_john
Disk shows Dead. Volume shows fine.
I have X-Raid with dual redundancy configured.  A disk failed on me and I went to pull out the bad drive.  Stupid me for not checking, but I pulled out disk 6 when disk 4 was the dead drive.  I was n...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Mar 19, 2018
    There's no important data on the swap partition. That's just used for temporarily storing what's normally stored in RAM if the RAM doesn't have sufficient space.
    So you can safely do what the error message suggested:
    # mdadm --zero-superblock /dev/sdf2
    then
    # mdadm --manage /dev/md1 --add /dev/sdf2
    If sdf2 is marked as a spare in md1 (you can tell this by checking the output of # cat /proc /mdstat ) you can force it to be used properly by doing e.g.
    # mdadm --grow /dev/md1 -n6
ProSupport for Business
