simonhang
Feb 02, 2015Aspirant
disk spindown problem with Ultra6
Hi, I have a Ultra6 with 6.2.2 OS. Disk spindown is enabled. It works, except I have to disable crontab, else it will spinup disk every hour. Also, samba is spinup disks. Any solution to this? ...
RX
Feb 02, 2015Luminary
I don't have an Ultra6 with FW v6.2.2. However, have you tried doing an OS reinstall? http://kb.netgear.com/app/answers/detai ... 9kbQ%3D%3D
You might want to consider using the Beta FW v6.2.3. It says there "Fix potential system hang on 4-bay units with disk spindown enabled" -- It might help even if your NAS is a 6-bay unit. Here is the link: viewtopic.php?t=78866
