matthew1471
Nov 15, 2018Guide
Disk test - Does it work or is one of my disks faulty?
Firmware 6.9.4 Hotfix 1
2 x WD40EFRX
Getting 20MB/s from a volume that has been balanced and defragmented looks like it might be something a WD drive does when it starts to fail.
Have r...
- Dec 21, 2018
Thanks.
I've thrown some more time at this and have determined both disks are failing but because they don't get much usage before the ReadyNAS is shut down for each evening the issues were masked.
I have performed a DIsk Test on 2 other ReadyNASes I own and they have all started correctly scanning. The 312 where the Disk Test fails shortly after issuing it now also has 1 drive that is showing a "Current Pending Sector Count" of 2.
Interesting that the drives appear healthy until a full disk test and that the WD firmware has a go-slow with no other errors triggered if the disks are starting to misbehave.. I suspect the raw throughput test worked as I only ran it on a bit of the drive.. and the Scrub worked (albeit slowly) because the WD isn't overly noisy with SMART logging.. It's only the Disk Test that shows up serious errors. I will make sure to keep my ReadyNASes more routinely disk tested now!
The disks are about 2 months out of the 3 year warranty (always the way isn't it)
I'll come back to update if the raw throughput recovers once my new drives arrive :)
matthew1471
Nov 15, 2018Guide
Tried with quota off and checksum off.. no difference. RN314 (RAID 5, same file) fine, RN312 (RAID 1) still slow.. All WD Red 4TB drives. hmm
matthew1471
Nov 15, 2018Guide
Read the raw bytes on both of the drives at the expected speed.. looks like it's something to do with the NAS / BTRFS.. Anything further I can check?
- StephenBNov 15, 2018Guru - Experienced User
My RN526 runs 4x6TB WD60EFRX in RAID-5 (XRAID). The last disk test took about 16 hours. That was with 6.9.3 though. NasTester shows about 290 MB/sec write speed and 360 MB/sec read speed (over 10GbaseT).
If you enable ssh, you could look at memory loading and also separate the filesystem performance from the network.
- matthew1471Dec 21, 2018Guide
Thanks.
- matthew1471Dec 29, 2018Guide
Performance issue discussed here : https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-RN3xx-Performance-Issues-145-Mbps-instead-of-500Mbps/m-p/1682457
