audetto
Oct 05, 2012Aspirant
DLNA -> PS3 strange "signal 15"
Hi, in the last period, about 1-2 months my DLNA -> PS3 streaming has been erratic. When I browse a folder in the PS3, (sometimes) it is empty, and after a few seconds it gets filled. And this ha...
matsleight
Feb 17, 2013Aspirant
I have broadly this problem too. I can play media fine (even 1080p) but when I try to browse my media using folder structure - get the 2104 error on PS3. Often I cannot see files/folders or they report as null.
What I have noticed is that if I go and show all videos eventually I can find the one I wanted, but the folder structure never gets updated so I cannot find the file I just played using the folders method.
Listing hundreds of files just to get to the one that no doubt starts with a late letter in the alphabet is quite tedious!
PS3 shows 100% wifi signal - streaming via BBC Iplayer etc all works fine too so I don't think its a network capacity issue. I am using a Readynas NV latest radiator/readydlna- could it be the NV is not quick enough to create the folders as a client browses via PS3 - hence the error?
I'll try the unpnp untick/tick next time. Anything else I should try?
