OOM-9
Jan 06, 2012NETGEAR Expert
Domain Join Issue - Information
I have found some helpful information for people that have issues joining the domain. The points to check when configuring the ReadyNAS to join the domain, and an additional option with logs to see wh...
gadgetman1
Jun 05, 2013Aspirant
Hi
I wonder if any of you will be able to help. I had problem joining the Duo V2 to my SBS2011 server. Check that the time is correct, FQDN and NetBIOS were setup correctly and so is the IP address and password. But still it just return with "Error in joining domain". There is no error code. Looking at the join_domain log file, it just say "fail to find DC for domain ..." but I am pretty sure I have type in the correct name, even with upper and lower case.
Where should I look now to fix the problem? I have tried with firmware 5.3.7 and now I am running the latest version of the firmware 5.3.8 which just came out May 23. Both have exactly the same problem. A Netgear tech support spent 3 hours looking at it and still could not figure out why and keeps asking me to reboot and reinstall the firmware :-(
Any guidance appreciated.
Regards
Peter
Regards
Peter
